So, I knew that if I posted that the problem was solved it would rear its ugly head again ... I've been chasing a hard cold (below -15ºC) start now for two years. Replaced ECT, crank and cam sensors and most recently replaced vacuum lines to the FPR. The last couple of days when it was -23ºC it started right up after a couple of cranks, to be expected in a 20 yr old vehicle. Today when it was -6ºC it refused to start. I was able to eventually get it started but as soon as I did the throttle began running away, up to 5000rpm before I killed the engine for fear of catastrophic failure. I cleaned the internals on the IAC again (done last year) and the electrical connections as well as another vacuum line (leads to relay on the fan shroud, I think its part of the regulation on the turbo) on the tree that looked like it might be split.
Still no luck, throttle continues to run away. I found that in blipping the throttle by hand that it was not returning to the idle position but could be forced back by twisting the recoil back. I have isolated this to what appears to be a vacuum assist connected to the pedal in the cabin, its not the throttle linkage in the engine bay as it returns no problem when tension is relieved on the cable. It appears that the vacuum assist is not pulling (or pushing I guess) the pedal back into the neutral idle position. Throughout this I pulled several codes at different times that all appear to be related to vacuum and idle (P1507, P1505 & P0505). Any ideas on where the vacuum line connected to the throttle goes or how I can trouble shoot this????
chasing demons
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
- rspi
Contact rspi..
Sounds like the cable is binding somewhere to me.
shegarty
- Year and Model: 1998
- Has thanked: 12 times
- Been thanked: 8 times
Sounds like that to me too rspi but the fact that it is throwing codes for vacuum related issues has me wondering if it could be a lack of proper vacuum somewhere. After watching the video, I now know that the actuator I can see is related to the cruise control ... I am hoping to have some time tomorrow to look at it again.
98 S70 T5 SE 298k km (daily)
87 740T sedan (current project)
previous - 90 745T; 94 855 T5
- rspi
Contact rspi..
Vacuum should NOT be on the bellow under the dash when the car is off. Pull that vacuum line off and see if the cable is still being pulled off stop.
A wire in the cable being broken can bind it.
Other codes may be a totally different issue.
- RickHaleParker
- Been thanked: 977 times
Only shows up when it is below freezing. Moisture in vacuum line freezing...?
Active
Past
Past
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
Moisture on your cable causing it to freeze? I lubricate my throttle cable with white grease.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
shegarty
So it looks like something must have gotten jarred out of alignment or a spring stretched in my attempts to get her started the other day. I loosened the throttle cable from both ends and it moved freely, I threw some lube in it just for good measure. When I reattached it I found that using the fine adjustment to add a bit of slack to the cable did the trick. She is now back to a smooth idle at the appropriate rpm and she has been starting, so fingers crossed? In a couple of days and several starts I have not had any more codes pop, vacuum or otherwise. I'll be sure to post back if I do
Thanks again for all the help and suggestions, you guys are awesome!
- 1435 Views
Last post by 850TurboTurtle
- 13 Replies
- 5420 Views
Last post by oragex
- 21862 Views
- 17 Replies
- 11561 Views
Last post by JohnnyBee323
- 43 Replies
- 20618 Views
Last post by ylwgto
