V70 Steering wheel squeeking - what is Low Temp Grease? Topic is solved
Has thanked: 2209 times
Been thanked: 1852 times
Since I replaced the broken dash mounts the steering wheel now squeeks when turned. I think I may gave wiped the grease of the clock-spring so the steering wheel contact is rubbing not sliding. Vida list a 'Low Temperature Grease' which naturally they no longer carry. Anyone tell me what/where I can buy this? I have heard of many types of grease but never a low temp one and as there is no spec for it I have no idea what to look for.
Teddy1975
Year and Model: 2007 V50
Has thanked: 1 time
Been thanked: 7 times
Post by Teddy1975 »
Hi Neil.
Any grease will do for this, it only means you don't have to use a high-temp graded grease, like for eg. wheel bearings.
/Teddy
Current: V50 2.0D, 2007, 6 speed manual
Previous: 850 2.0L N/A, 4 door 1996 manual, 740 2.3L N/A, 5 door 1992 manual, and S70 2.5T 1999 manual
Thanks Teddy. My other concern not having a specification for the grease is does the grease need other properties like conductive/non-conductive and that sort of thing.
Thanks for the help.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Do the P80 have that big rubber boot where the column goes trough the floor? There may be a small bearing at the top that gets rusted, seizes then rotates inside the boot making some annoying noise against the rubber
Teddy1975
Has thanked: 1 time
Post by Teddy1975 »
Sorry, not sure about conductive or non-conductive. I'd think if it had to be conductive, VIDA would say so.
Reason for thinking it may have to be conductive is the contact point for the horn/airbag is electrically operated and I would expect if it was non-conductive it may prevent function of these items.
I know about the floor bearing and it is a good suggestion, except the noise is coming from the steering wheel area and sounds almost like plastic on plastic as if the steering wheel is rubbing on the steering column plastic cover. But why is it started doing this now other than I just refitted it. I will re-check the covers for alignment to exclude them from the equation.
Appreciate the help guys.
mecheng
Year and Model: 1998 Volvo S70 T5
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
Lithium grease is dielectric, and has relatively low viscosity which is what I think you need. And it doesn't smell.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
That was what I was thinking and I have loads in spray form which would mean not having to possibly pull the steering wheel and airbag again. Worth a try and I'll post back if it is successful. Thanks for the heads up!
Well I have identified a part number and the actual grease the local dealer uses for this purpose. It is a Wurth product (they only use Wurth products now):
https://shop.wurth.ca/lubricants-grease ... 93.107002/
Although it has a Volvo part number # 1161762, they do not supply it to customers.
I tried Wurth Canada who are happy to supply it in a minimum qty. of 3 tubes at $20 for each tube and a further $15 CDN for shipping. Can't find a supplier that can sell the product locally to use regular folks. So it is $75 CDN (+ tax) for for a teaspoonful of this grease! And then what the heck would I used the rest for?
Totally nuts!
From the specification (which makes no mention if it being possibly conductive) can anyone recommend an alternate with the same spec?
Eddystone
Year and Model: 1967 Ford GT40 Mk IV
Has thanked: 63 times
Been thanked: 81 times
Post by Eddystone »
For what it's worth, I removed the dash top and pulled the dashboard toward the firewall to tighten it up and get rid of squeaks. Dashboard squeaks are gone, however, when turning the wheel pretty far off of center as in backing out of a parking space the column makes a rubber squeaking noise. I think the dash moved slightly in relation to the steering column.
Point: I never pulled the steering wheel, so that's not where the noise is coming from in my case.
Your problem my have to do with the column in relation to the dash. (Haven't attacked mine yet.)
If you grease anything that has plastic parts, don't use a grease or oil that weakens plastic or nylon.
All U.S. market models.
All running and on the road.
