05 S60 2.5T Hissing Sound, Passenger side intake Topic is solved
allan4187
Year and Model: 2005 s60, 2001 s80
Post by allan4187 »
When the car is running, I can hear a sucking or hissing sounds coming from somewhere, I think, underneath the intake manifold near the power steering pump. Is there a common valve or hose that fails there? It is very hard to pinpoint and/or get to that area to check closer.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
At warm idle, pull the dipstick and/or undo the oil filling cap. Also watch for fumes out of the dipstick tube. Could be a blocked PCV, urgent repair so you don't blow costly engine seals. May google up for details and don't forget to inspect the oil passage to the oil pan.
allan4187
Post by allan4187 »
I thought that too, but it is not that at all.
Has thanked: 1609 times
Been thanked: 4063 times
Banjo bolt with a hard plastic vacuum line under intake manifold, cylinder 1
Could Also be broken PCV big hose
oragex
Post by oragex »
Is it continuous and at idle too? Can you record the noise on Youtube?
allan4187
Post by allan4187 »
oragex wrote: 13 Jan 2018, 19:17 Is it continuous and at idle too? Can you record the noise on Youtube?
Continuous at idle. Sort of goes away when revved up, but that could be because the engine sound drowns it out.
abscate wrote: 13 Jan 2018, 17:29 Banjo bolt with a hard plastic vacuum line under intake manifold, cylinder 1
thanks I'll check those out. Sounds about right.
allan4187
Post by allan4187 »
Thanks abscate. It was the single small line that came off the banjo bolt that had came loose from where it connected to the can. Didn't improve any of my other issues, but at least that hissing went away!
Outstanding Red Team.
It was either that or a missing Cobra....
