2004 T6 P0040 code Oxygen sensors signals switched
Joppadad
- Year and Model: 2000 C70 convertible
I have searched this forum and did find a relevant post to this issue, but it did not answer my question. 2004 XC90 2.9l is getting code P0040 O2 Sensor Signals Swapped Bank 1 Bank 2 Sensor 1...I know that bank 1 is cylinder 1-3 and then bank 2 is cylinder 4-6, I know where they plug in and here is my question. I know that the turbos have been replaced as I have the paper work, so they MAY have been swapped. What I need to know is which connector the 1-3 bank is supposed to be connected to, the white or the black connector?
2000 C70 convertible 2.4L LPT
2004 S60R 2.5L AWD
2004 XC90 T6 AWD
2004 S60R 2.5L AWD
2004 XC90 T6 AWD
- RickHaleParker
- Been thanked: 978 times
Try switching the two, clear codes, see if the P0040 comes back. If it does come back, switch back and start looking for a different cause.
ECM-280C (P0040) Switched front heated oxygen sensors (HO2S). Faulty signal
Diagnostic trouble code (DTC) information ECM-280C
Condition
Diagnostic trouble code (DTC) ECM-280C is stored if the engine control module (ECM) detects that both front heated oxygen sensors (HO2S) bank 1 and 2 have been switched (mounted in the incorrect bank of cylinders). The diagnostic trouble codes (DTCs) are diagnosed when the engine has been idling for 10 minutes
Substitute value
Condition
Substitute value
- Long-term fuel trim is switched off
Three-way catalytic converter (TWC) diagnostics are disabled.
- Faulty signal:
Front heated oxygen sensors (HO2S) are mounted in the incorrect cylinder banks
Fuel injection system leakage
Both the front heated oxygen sensors (HO2S) are defective.
- Malfunction indicator lamp (MIL) lit.
Active
Past
Past
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
Since the connectors are color coded, is it likely that the sensors are installed in the wrong holes? Haven't looked at the routing on mine (ps-they're both dead, so I'll find out soon enough!)
Current Volvos:
