Long Cranking Time on 99 S70 GLT
Cricket502
Year and Model: 99 S70 GLT
Post by Cricket502 »
So I've been having this problem since maybe Thanksgiving and I still can't figure it out. The car still starts so it's more of an annoyance than anything (so far), so that's why I waited so long to post. That and it takes a long time to scour the entire internet for a solution...
From a cold start, it can take anywhere from 1 second to 10 seconds of cranking before the car finally starts. It usually starts right up once warm. Turning the key to position II for a while to try and prime the fuel pump first doesn't seem to change much. Once it starts it idles and runs just fine, occasionally the first split second after starting has a bit of a kick but that's it. Around Christmas I started getting a random misfire check engine code on the highway and when accelerating hard. Based on everything I read, it sounded like my fuel pump check valve or pump itself was going bad, so I replaced the fuel pump and fuel filter. No more misfires, but I still have the long cranking problem.
The battery is only 1.5 years old, so I don't think it's that. I have had check engine code P0455 for a gross evap leak for years (tried replacing the gas cap, no luck and no problems due to the code, unless this is related) but that's the only CEL I'm getting after putting in the new fuel pump.
I just checked the car after sitting overnight and there was zero fuel pressure. Nothing came out of the Schrader valve under the hood. Is that normal, or should there be some pressure even after sitting overnight? What else could be causing the long cranking problem?
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Regular priming,just before you start it is a MUST.System is designed that way.That's why the fuel pump runs about 2 seconds with key in pos.II...alowing the system to prime before start.
You need to try to prime it 2-3 times before you start it in order to eliminate check valve problem.
So....key in position II wait 2 seconds...back to pos.I and immediately back to pos.II.
Do that 2-3 times and 3rd time start the engine.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Cricket502
Alright, I followed those directions and it fired right up on the third crank. So I'm definitely losing fuel pressure. I'm thinking possible causes would be a faulty check valve in my new fuel pump from FCP, an actual leak in a fuel hose, or a leak in another component of the fuel system (injectors, fuel pressure dampener, not sure what else)? Anything else to look at, or specific places that are common to leak?
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
The check valve is located in the fuel pump cartridge itself. If you only replaced the pump itself and reused the housing (which is typical) then it won't fix a bad check valve.
If you are not holding pressure at the rail then the only options are to change the fuel pump cartridge or add a check valve to the fuel line.
Has thanked: 1609 times
Been thanked: 4065 times
The specs o n a 1999 are 52 psi furl pressure at the rail, and at least 29 psi at the rail after 20 minutes. No overnight spec. That isn't a bad thing to measure though so maybe that's my project this week.
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
You're welcome to come measure mine as I fire it up at ~0755 @ 6 F... Hasn't been run since 1830 yesterday.
P.S. it's colder than cold out
I'll leave the fuel pressure gauge out in the tundra for you...
Don't push the " incoming Missile button" by mistake this morning. (MRS Abscate actually is on that team in NYS)
Cricket502
I replaced the entire fuel pump assembly, not just the pump itself, so it sounds like the check valve should have been part of that new assembly. I'm going to poke around when I get a chance to pull my car into the garage today (way too cold outside here too) and see if I see or smell a leak anywhere. If not, I'll hit up autozone and see if they have a fuel pressure gauge I can borrow to get more info about my pressure drop over time.
misha
Post by misha »
What brand is your new fuel pump/assembly?
Is it new or used?
Large vacuum leak can affect starting and running.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Cricket502
The fuel pump was a Delphi fuel pump assembly, new from FCP Euro. I'll look for bad vacuum hoses too while I'm under the hood
