Just got home and upon getting out of the car there was a horrible chemical burning smell. It went away very quickly once I was parked with the car off.
When I left for home I made a three point turn and there was a loud creaking/popping sound when the wheel was to the extreme right. Checked the PS fluid and everything else just now and all levels appear good.
I was thinking air in the PS lines given I replaced the Resevoir the other day. But I’ve driven 100+ miles since then and this was the first weird steering symptom.
Chemical burning smell Topic is solved
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
There are a number of fluids and compounds that each make different smells. Unfortunately smells can be highly subjective...
Does it smell sweet? Does it smell corrosive/acidic? Does it smell oily?
Does it smell like clutch material? If so, check for a stuck/frozen brake caliper if you have an automatic.
- RickHaleParker
- Been thanked: 978 times
Sweet smell - Antifreeze
Rotten eggs/Somebody farted - Battery acid (hydrogen sulfide).
Burning Rubber - Belts.
Oil - self explanatory.
Dinner burnt - Could be a lot of things.
Active
Past
Past
- jtp
- Year and Model: 99 v70R
- Has thanked: 11 times
- Been thanked: 10 times
It definitely wasn’t a sweet coolant smell, very acidic. Gonna get it into the shop today, everything looks good right now leaving the house
99 V70R AWD
Almost 155K Miles
Breaking is how I know it’s working
98 S70NA (sold)
95 850 Turbo Wagon (RIP)
Almost 155K Miles
98 S70NA (sold)
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
If it's a sharp acrid smell, be careful as that can be burning wires/electrical smoke or fire. I'd check all fuses to be safe. Could be something like power steering fluid leaking onto something hot though which may cause a bad smell too.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
- RickHaleParker
very acidic
Battery and charging system.
Active
Past
Past
Oil leak onto exhaust manifold will make your eyes hurt.
When the battery or alternator fail hard enough to smell, it's usually visible boiling and acid venting.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
I'd concur
The time I got this smell I just had installed a flexible downpipe and secured it with a 'high heat' J-B weld stuff. Drove it straight to the garage to have the stuff removed and the pipe welded
- jtp
I drove it into work (I work at a VW dealership) and gave it to the top guy, not a Volvo guy but he's really good. You'd think your car gets priority if you work at a shop but on a busy day like today thats not really how it goes. Hes gonna get it in this afternoon so Ill report back.
Trying to get this thing fixed up would be a lot easier if it stopped breaking
99 V70R AWD
Almost 155K Miles
98 S70NA (sold)
Almost 155K Miles
98 S70NA (sold)
I’ve heard Norwegians are flocking in to DC with burned kippered herrings, are you downwind?
- 538 Views
Last post by SuperHerman
- 631 Views
Last post by Ozark Lee
- 3119 Views
Last post by Clemens
- 12 Replies
- 3035 Views
Last post by Jibbaman150
- 1657 Views
Last post by aaronlife
