My climate blower has been chirping on braking (when the cage is thrown forwards, the bearing is complaining - very light noise, like a quiet cricket)..
I thought I would throw a new one in there.
TYC Brand $99 9171479
Behr Brand $235 31320393/9171479
Volvo OEM $325 31320393
Ouch!
2005 V70NAM56 Motivation to service/lube Climate Blower motor 31320393
- Been thanked: 4064 times
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
I'd be highly motivated to visit the Volvo boneyard.!abscate wrote: 16 Jan 2018, 11:19 My climate blower has been chirping on braking (when the cage is thrown forwards, the bearing is complaining - very light noise, like a quiet cricket)..
Ouch!
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
I even removed the faulty bearing which is a bushing type that sits unde the fan blade - it's this bearing that is under humidity and gets corroded and starts seizing. I cleaned it really well, lubbed and reinstalked. Two years later it started chirping again in v cold days.
There are plenty of used blowers on Ebay, many from dry or at least warm states (Florida?). Tip: look at the metal rod in the center of the fan blades, if it's not rusted from humidity it should be a safe purchase.
Hmmm, maybe buy the TYC and lube the original one as a backup. eBay would have to be real cheap, like $20 , to fight this option.
Car is laid up with fuel delivery problem right now so good time to deal with it,
- mrbrian200
- Has thanked: 7 times
- Been thanked: 84 times
Oil/grease sounds like a good idea at first glance on this type of bearing. However the problem is that fine dust sticks to the grease instead of falling or blowing away which transforms the lube into a dense sticky gum. So it's only a short term solution unless you enjoy taking the fan motor apart, cleaning and re-lubing it on a regular basis. Also, this type of bearing can get very hot which will break down most common multi purpose type lubricants.
If the armature isn't worn you can replace the bearing to make it like new...if you can find the right one/size.
I don't mind it but I can't stand the flak from SWMBO who will have to drive the BMW slush box as the clunker....So it's only a short term solution unless you enjoy taking the fan motor apart, cleaning and re-lubing it on a regular basis
- 822 Views
- 1937 Views
- 388 Views
Last post by Blacklab467
- 14 Replies
- 5849 Views
Last post by V70r carbon
- 3225 Views
Last post by BlackBart
