First at all try to reconnect battery one more time.
But, you have to do it correctly:
remove key from ignition, hold on 5 minutes, then disconnect battery.
After waiting 1 minutes, put key to ignition and turn it to second position (position before Start position).
Then connect battery.
If it is not help, maybe you right and you have issue in the UEM.
You can buy used set UEM+Remote, but remember: it should be correct set with right software number for your car exactly.
Or, if you have a DiCE, you can try to use online service for transfer your original data from you UEM to used UEM.
volvo s60 mirror module , remote control module
- 394 Views
Last post by edd821
- 1623 Views
Last post by phils94850
- 1676 Views
Last post by 850_GLT_Owner
- 2062 Views
Last post by yagger
- 5023 Views
Last post by Nikolaech
