Hi Folks
Great site! My Aircon fan has stopped working and I suspect that its the solenoid/resister that has blown. Is there a way to bypass this unit, even if i have to install a toggle switch?
AC motor solenoid bypass possible? - 2004 XC90
- Has thanked: 2854 times
- Been thanked: 1332 times
Global stickyed temporarily - anyone have any suggestions?
- RickHaleParker
- Been thanked: 977 times
The fan speed controller is just a current limiter on the ground side of the fan. If you ground the fan's negative terminal, it will run full blast. If you place a resistor between the fan's negative terminal and ground it will run at a slower speed. You should use wire and resistors that can carry the current of the fan without burning up and burning down your Volvo.
Active
Past
Past
- 4704 Views
Last post by oragex
- 1942 Views
Last post by precopster
- 1635 Views
Last post by vvvolvo
- 884 Views
Last post by piusg
- 17 Replies
- 5049 Views
Last post by Katronite
