XC70 Turbo, Camshaft and Crankshat Alignment
Joekawimbe60
- Year and Model: XC70 2006
My mechanic opened the engine to replace the head gasket, but he did not lock the cams, and now has failed to start the car because he is battling with aligning the Cams and the Crankshaft to get the timing right. He has been using the "traditional TDC" method, which seems to have failed. Help, please.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
See the updated pdf file for the complete proceedure, this assumed you have lost all reference of where things started.Joekawimbe60 wrote: 18 Jan 2018, 00:26 My mechanic opened the engine to replace the head gasket, but he did not lock the cams, and now has failed to start the car because he is battling with aligning the Cams and the Crankshaft to get the timing right. He has been using the "traditional TDC" method, which seems to have failed. Help, please.
www.matthewsvolvosite.com/forums/viewto ... 50#p427042
- 3068 Views
Last post by vmaxmike
- 12 Replies
- 3224 Views
Last post by dono
- 11 Replies
- 38027 Views
Last post by Volvoman809
- 1563 Views
Last post by 3carmark
- 825 Views
Last post by Ksg11
