First things first - does the fluid smell burned? If it hasn't been changed recently I would replace the existing fluid.
Which process did you utilize to check the fluid?
So are you getting the blinking up arrow or the solid up arrow?
Transmision mission
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
- wizechatmgr
If you put it in reverse, do the reverse lights go on?
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
Hey Ranger, welcome aboard. Is the car new to you?
You say it stops working, typo, or intermittent problem?
Yes 98 XC box will fit. I'll edit and attach a link that is comprehensive with interchange info (also, search dealer website parts list using your VIN)
http://forums.swedespeed.com/showthread ... s-Listings
For raising car, best to go with stock height springs and shocks. ( sell your lowering stuff in classifieds here)
Current Volvos:
- Has thanked: 2199 times
V70 XC has different front struts and rear hub assemblies to yours, otherwise a lot of change overs. On a 98 most for the driveline is the same except for that mentioned earlier.
- 407 Views
Last post by Jackson5
- 599 Views
Last post by crussell83
- 566 Views
Last post by FLXC90
- 1226 Views
Last post by matthew1
- 675 Views
Last post by oragex
