2000 v70 xc horrible gas mileage
Bearj
Year and Model: 2000 v70 xc
Post by Bearj »
Anyone have any idea why my car averages 14-16 mpg no matter how it is driven. Its been like this since I got it and I'm trying to figure out what all to look at besides the plugs and ignition coil packs
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
When were the O2 sensors last replaced?
Do you drive spirited or laid back?
wizechatmgr
And I believe welcome aboard is in order :)
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
Bearj wrote: 20 Jan 2018, 00:04 Anyone have any idea why my car averages 14-16 mpg no matter how it is driven. Its been like this since I got it and I'm trying to figure out what all to look at besides the plugs and ignition coil packs
That's about the mileage I get if I run 87 durring mixed driving. 19 to 20 with 93. My engine has one more turbo and cylinder than yours, but the five turbocharged cars I had got about the same. Try running a tank of brand name 93. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
Has thanked: 1609 times
Been thanked: 4065 times
My mileage coming home last night was horrible but my trip was short...no idea why...
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
O2 sensors,tire pressure,vacuum leaks,air filter,spark plugs/gap,low octane gas....all of these affect gas mileage.Wrong timing also.
All of those can be checked and replaced if necessary and low octane gas should not be used.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Timing
Aftermarket ignition parts
Low tire pressure
Bad brake caliper
Bad thermostat.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
14-16 seems low. Even with my "spirited" driving style, I get around 20 (I think... been a while since I've tried to calculate it).
You didn't mention if you changed your plugs, so that's one place I'd start, along with the air filter. Also as misha mentioned, vacuum leaks are a possibility, especially if it's running a little rough. Robert mentioned some easy things to overlook which will greatly affect gas mileage.
If you aren't using the best octane gas available (91 or 93 depending on your location) that is very important. These cars do NOT like 87 octane (look through the burned valve threads). Fill it up with premium and a bottle of Techron to clean things up, that'll probably get you a couple extra miles per gallon.
abscate wrote: 20 Jan 2018, 06:03 image.jpegMy mileage coming home last night was horrible but my trip was short...no idea why...
Exactly double... nice!
