my 91' 740 will not go into overdrive until at least 10 miles go by. then i have to pull over and go through gears. I replaced overdrive relay to no avail. anyone know about this? I hear BMW's have this issue too.
thanks
Ed
Over 10 miles for OverDrive to work
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
Other things to check:
Gearbox oil.
Overdrive solenoid and wiring.
Switch in top of gear lever.
Gearbox inhibitor switch.
Bill.
Gearbox oil.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
I suspect the tranny fluid as suggested by billofdurham. It seems like something has to get thoroughly warmed up for your OD to work.eradics wrote:my 91' 740 will not go into overdrive until at least 10 miles go by. then i have to pull over and go through gears. I replaced overdrive relay to no avail. anyone know about this?...thanks
Ed
Don't know if yours is automatic or manual.
Especially if it's an auto tranny, I'd do a good thorough fluid flush, or get one done. There might be some partially blocked passages that restrict the flow till things get thoroughly warmed up. If its a standard tranny then it could be the same issue - but I've only worked on the auto ones.
'89 245 NA, 951 ECU, open-front airbox, E-fan, 205/65-15's on steelies, IPD sways, E-Codes, amber front corner reflectors.
Wifemobile: '89 245 NA stock.
Spare: 90 244 NA, runs.
hertfordnc
- Year and Model: 1991 240
I second the tranny flush. My overdrive was taking as much as 50 miles to work rigth. It worse as the weather is cooling. I drained and replaced the trans. Now it engages much quicker. Obviously it's still not right. I need to have a proper flush done but I'm still researching how the OD works and deciding weather I want to open it up and look for something specific to clean or replace.
dave
dave
- 5492 Views
Last post by ektrules
- 1978 Views
Last post by matthew1
- 2365 Views
Last post by carboncow
- 79 Replies
- 28635 Views
Last post by Arcticsilvere39
- 302 Replies
- 46361 Views
