Another issue with my 2004 XC90.
The headlight flashes randomly without any input even though the light switch is at 0 but works fine when the switch is turned to the on position. The problem disappears after driving around for sometime. Also, I am unable to select the hi-beam mode (it automatically switches back to low-beam). Please help.
Headlights go on and off randomly during day.
- June
- Has thanked: 523 times
- Been thanked: 261 times
Unsure of the off and on part, but on my 2004 S80 the high beams do the same when the switch is at 0 and work fine in the on position. I leave the switch in the on position at all times since the car is equipped with daytime running lights.
My 2002 S80 T6 had HID headlights option and turned off and on with a light sensor on the dash rather than staying on as the daytime running lights. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
jpeter
- Year and Model: 2004 XC90 2.5T
- Has thanked: 6 times
My car is not equipped with the DRLs and driving around with headlight on during daytime can attract a fine here in Qatar I believe. I am getting angry stares from others due to this stupid inadvertent flashing. Sheesh!!
- RickHaleParker
- Been thanked: 980 times
Sounds to me like your DRL are intermittent or the flash to pass/headlights are coming on when it should not be coming on.
On the 2004 I think the DRL is turned on/off in the Central Electronic Module (CEM).
If it is flash to pass/headlights coming on, that could be flaky wiring or flaky switch.
Position 0 is off with day time running lights where required or turned on where not required.
Position I is low beam driving, the stalk is flash to pass.
Position II is high beam driving, the stalk is High/Low.
Active
Past
Past
jpeter
In my case,
Position 0 all lights are off ( flash/pass light keeps flashing randomly, it subsides after driving around a while but tends to return if the car is switched off and started again).
Position I Just the park lights.
Position II Low beam turns on and switching to high beam via the stalk (but as you pull the stalk towards the steering wheel, it doesn't stay in high and goes back to low beam). Looks like my car doesn't have DRL.
Just had Bosch Service Center inspected and they told me it could be the ballast (I am not convinced). Rick, as you mentioned, it might be frayed wires. Will keep posted.
- June
If it is the high beams that flash, it seems to me to more likely be the high beams switch getting flakey. My right turn signal is flaky every now and then. I found if I run the stalk up and down quickly like fifty times, the right signal works fine for a good half year. Like the signal stalk might have a bad contact. Maby if you flip the high beams quickly like 50 times and suddenly it stops for a while you'll know it is the stalk that is bad. What can it hurt? Junejpeter wrote: 22 Jan 2018, 04:10 In my case,
My Volvo cars owned
1996 960 ordered
1996 960 ordered
- mrbrian200
- Has thanked: 7 times
- Been thanked: 84 times
Probably the stalk/switch. My experience with my own car ('06) makes me think a possible culprit might the white grease volvo uses on chassis moving parts (latches, switches, hinges, door stops) has hardened into a thick putty and sticking the mechanism. However, there is an small circuit board on the side of these with a few SMD components...capacitors, transistors, resistors... which raises the possibility of small component failure on the board such as an intermittent shorting capacitor or resistor fooling the logic into thinking you're pulling on the stick (replace it).
jpeter
Thanks. Where would this circuit board be? In the on/off switch?mrbrian200 wrote: 22 Jan 2018, 13:11 Probably the stalk/switch. My experience with my own car ('06) makes me think a possible culprit might the white grease Volvo uses on chassis moving parts (latches, switches, hinges, door stops) has hardened into a thick putty and sticking the mechanism. However, there is an small circuit board on the side of these with a few SMD components...capacitors, transistors, resistors... which raises the possibility of small component failure on the board such as an intermittent shorting capacitor or resistor fooling the logic into thinking you're pulling on the stick (replace it).
- mrbrian200
The circuit board is integrated into the switch/stalk assembly down in where the harness plugs in. The board doesn't look terribly complex but there is a little more than simple mechanical switches down in there.
