Did you know? 🤔
Clean this sensor if you have not
Help, Advice, Owners' Discussion and DIY Tutorials on the Volvo S80 model. Sometimes called an "executive car", the S80 was and continues to be Volvo's top-of-the-line passenger car.
Has thanked: 361 times
Been thanked: 1106 times
Trinidad & Tobago
Re: Clean this sensor if you have not
Post by abscate » Tue Jul 21, 2020 11:19 am
Don’t forget to remind us again September, June
Link To Volvo Glossary
oragex
Year and Model: S60 2003
Has thanked: 99 times
Been thanked: 290 times
Canada
oragex
Post by oragex » Thu Jul 23, 2020 4:02 am
I'm astonished by the amount of fluffy I see when I check radio units at the junkyard. Pretty sure many owners are not aware of this, and imagine they complain about climate not working properly or worse - check into small garages and had parts replaced/serviced for no reason. Often times I see these completely packet with fluffy stuff. Not sure it's even easy to suck out these when it's so packed - and surely inserting anything through the small grid is a recipe for repairs from broken sensor. The small fan that sucks in all these also gets packed but it's easily cleaned by removing the CCM and should be part of the maintenance as when it gets clogged it stops spinning and doesn't bring air properly onto the sensor. Also good to look with a flash light through the grid make sure the small tunnel behind the sensor is also clean, so the air can freely flow to the small fan
