2008 V70 - HVAC whine during colder months
its4uok
Year and Model: 2008 V70
Post by its4uok »
I'm looking for some help diagnosing a noise on my 2008 V70. There is a noticeable whine coming from the dash area which changes pitch with the RPMs of the engine. The noise completely disappears if I shut the HVAC off which has always led me to believe the blower motor is the culprit. The odd aspect of this is that the noise is really only obvious when temperatures are below 45 degrees F.
Considering the complexity of swapping out the blower motor I'd like to be certain that is the issue prior to tackling that.
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
I would reach in and unplug the blower motor when the whine is present, see if that stops the whining.
If it does stop whining, next I would turn off the HVAC and power the blower motor directly with jumper wires for confirmation.
Active
Past
its4uok
Post by its4uok »
Played with this a little more last night and did find that the whine goes away when you turn the A/C off. Fan was still blowing and it was quiet.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
The cabin fan blower does go bad and is located right behind the glove box, it makes a high pitching noise, like a complain. It starts in cold weather and changing the fan speed at the knob may change or even take away this noise.
However the cabin fan is not affected by the engine revs, so perhaps you have a different issue.
The bearing on the air climate compressor (located just under the alternator) starts getting dry at 100K miles or so and it's making a friction noise. This bearing can be replaced relatively easily without removing the compressor. Finally, just above the alternator is the power steering pump. All these three are driven by the same belt. The power steering pump is the one more likely to make a 'whine' noise in particular if the fluid is low or if the fluid is the wrong type - it should be a clear green almost fluo color. The pump rarely goes bad, only the fluid needs replaced with the correct one, the Pentosin chf 201 or 11.
I would ask a mechanic to remove or toss the accessory (serpentine) belt, and to spin all these pulleys by hand, then check the fluid in the power steering pump reservoir.
RickHaleParker
Now I'm baffled as to why this is an issue. Who needs A/C at 45°F?
Active
Past
its4uok
Post by its4uok »
I'm going to have my independent mechanic look at it as soon as he located a part for a different issue (Brake Booster). Some of the other posts I've looked at suggest low Freon can create this noise. I'll do my best to update the outcome once we get it resolved.
As for A/C in the winter, you can run A/C and Heat to dry out the air in the cabin and prevent moisture on the windows. In this case though we are just setting the Climate Control to Auto and letting it make the decisions for us.
Has thanked: 1610 times
Been thanked: 4065 times
HVAC fan on a P3 is a major Charlie Foxtrot. Diagnose first.
its4uok
Post by its4uok »
Just to closing the loop on this one.
Long (and not useful) story but we ended up going ahead and replacing the compressor and i have not heard the whirring noise since.
Thanks for closure. AC is triggered whenever one selects defrost, but only above 35F.
I think I may have found the reason for this, I left some PAG oil outside and it turned into Jello in the low 30s
