Did you know? 🤔
2008 V70 - HVAC whine during colder months
Help, Advice, Owners' Discussion and DIY Tutorials on the third generation Volvo V70 wagon and XC70 crossover, and second generation S80. Are you an owner? Prospective owner? Get in here and join us! Start a new topic or comment on an existing thread.
2008-2016 V70
2008-2016 XC70
2007-2016 S80
its4uok
Year and Model: 2008 V70
Has thanked: 0
Been thanked: 0
United States of America
its4uok
Post by its4uok » Tue Jan 23, 2018 9:13 am
I'm looking for some help diagnosing a noise on my 2008 V70. There is a noticeable whine coming from the dash area which changes pitch with the RPMs of the engine. The noise completely disappears if I shut the HVAC off which has always led me to believe the blower motor is the culprit. The odd aspect of this is that the noise is really only obvious when temperatures are below 45 degrees F.
Considering the complexity of swapping out the blower motor I'd like to be certain that is the issue prior to tackling that.
RickHaleParker
Has thanked: 3 times
Been thanked: 311 times
RickHaleParker
Re: 2008 V70 - HVAC whine during colder months
Post by RickHaleParker » Tue Jan 23, 2018 9:48 am
I would reach in and unplug the blower motor when the whine is present, see if that stops the whining.
If it does stop whining, next I would turn off the HVAC and power the blower motor directly with jumper wires for confirmation.
Platform: P80 1998 C70, B5234T3, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0, Plant Torslanda Sweden.
its4uok
Has thanked: 0
Been thanked: 0
its4uok
Post by its4uok » Wed Jan 24, 2018 7:22 am
Played with this a little more last night and did find that the whine goes away when you turn the A/C off. Fan was still blowing and it was quiet.
oragex
Year and Model: S60 2003
Has thanked: 81 times
Been thanked: 177 times
Canada
oragex
Post by oragex » Wed Jan 24, 2018 8:45 am
The cabin fan blower does go bad and is located right behind the glove box, it makes a high pitching noise, like a complain. It starts in cold weather and changing the fan speed at the knob may change or even take away this noise.
However the cabin fan is not affected by the engine revs, so perhaps you have a different issue.
The bearing on the air climate compressor (located just under the alternator) starts getting dry at 100K miles or so and it's making a friction noise. This bearing can be replaced relatively easily without removing the compressor. Finally, just above the alternator is the power steering pump. All these three are driven by the same belt. The power steering pump is the one more likely to make a 'whine' noise in particular if the fluid is low or if the fluid is the wrong type - it should be a clear green almost fluo color. The pump rarely goes bad, only the fluid needs replaced with the correct one, the Pentosin chf 201 or 11.
I would ask a mechanic to remove or toss the accessory (serpentine) belt, and to spin all these pulleys by hand, then check the fluid in the power steering pump reservoir.
2003 2.4i S60 automatic 125k miles
DIY Volvo repairs videos https://www.youtube.com/playlist?list=P ... s0FSVSOT_c
RickHaleParker
RickHaleParker
Post by RickHaleParker » Wed Jan 24, 2018 9:55 am
Now I'm baffled as to why this is an issue. Who needs A/C at 45°F?
its4uok
Has thanked: 0
Been thanked: 0
its4uok
Post by its4uok » Mon Jan 29, 2018 8:04 am
I'm going to have my independent mechanic look at it as soon as he located a part for a different issue (Brake Booster). Some of the other posts I've looked at suggest low Freon can create this noise. I'll do my best to update the outcome once we get it resolved.
As for A/C in the winter, you can run A/C and Heat to dry out the air in the cabin and prevent moisture on the windows. In this case though we are just setting the Climate Control to Auto and letting it make the decisions for us.
Has thanked: 192 times
Been thanked: 620 times
Trinidad & Tobago
Post by abscate » Fri Feb 09, 2018 10:29 am
HVAC fan on a P3 is a major Charlie Foxtrot. Diagnose first.
its4uok
Has thanked: 0
Been thanked: 0
its4uok
Post by its4uok » Fri Apr 06, 2018 12:10 pm
Just to closing the loop on this one.
Long (and not useful) story but we ended up going ahead and replacing the compressor and i have not heard the whirring noise since.
Trinidad & Tobago
Post by abscate » Sat Apr 07, 2018 5:04 am
Thanks for closure. AC is triggered whenever one selects defrost, but only above 35F.
I think I may have found the reason for this, I left some PAG oil outside and it turned into Jello in the low 30s
