My 1996 Volvo 850 was in an accident and the radiator was damaged which allowed coolant into the transmission cooler. I've replaced the radiator but now I am wondering how to get as much contaminated trans fluid out of the transmission as possible before I refill it. I know I can pull the drain plug, but there will still be fluid in the transmission itself. If I leave the lines that go to the transmission disconnected from the new radiator/cooler and start the car, will it pump out the remaining contaminated fluid? If so, do I need to put the car in drive to do this? Obviously, I am concerned about damaging the transmission so any input on how to avoid doing so would be appreciated.
Thanks in advance for any constructive input.
Erik
Best way to get trans fluid out of transmission?
- Has thanked: 311 times
- Been thanked: 817 times
With the car in park, disconnect the top line from the radiator, and hook a clear tubing onto it leading to a container. Start the car with trans in park, and it will start pumping fluid. Your best bet is to do a continuous exchange until you get bright pink fluid pumping out of the trans. That will take about 14 quarts. You can feel very comfortable using cheap DexIII from Walmart for this procedure, thats what I give all of my 850/x70 transmissions.
This procedure is written in great detail in many places and videos, here is one of the original posts about how to do it: viewtopic.php?t=8767
Good luck!
Erik
Good luck!
Erik
- Been thanked: 4064 times
Erik - is this in famous Gibbons method, invented by..
- Has thanked: 2197 times
- Been thanked: 1851 times
Looks like a mechanic that worked on my car....maybe he was so bad as they paid him peanuts...!
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
He was a real "Grease Monkey", huh?
Current Volvos:
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
This topic turned funny, yet strangely true.
- 1027 Views
Last post by Junkman1
- 20 Replies
- 2165 Views
Last post by Goupil
- 8274 Views
Last post by Geevs
- 15 Replies
- 3607 Views
Last post by GreenMagicMan
- 940 Views
Last post by martin calva
