Best performing and lowest cost penetrating oil is DIY.
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
The DIY penetrating oil is a 50/50 mixture of 100% Acetone and Dextron/Mercron ATF.
  • Mix only what you need today in a spray bottle. This mixture has a short shelf life.
    The two fluids repel each other like oil and vinegar. You have to shake the bottle vigorously before spraying.
Machinist's Workshop magazine test results.
Pentrating oil / Average load / Price per fluid ounce
None / 516 pounds / NA
WD-40 / 238 pounds / 25¢
PB Blaster / 214 pounds / 35¢
Liquid Wrench / 127 pounds / 21¢
Kano Kroil / 106 pounds / 75¢
ATF-Acetone mix / 53 pounds / 10¢
Active
Past
Rattnalle
Year and Model: 2004 V70 2.5T
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
Interesting. Any personal experience?
RickHaleParker
It has gotten he out of some PITA jams. My father was an Automotive Design engineer, he taught me this one back in the 60s.
Active
Past
Rattnalle
Post by Rattnalle »
Using a regular plastic spray bottle or something more refined?
RickHaleParker
I just use a plastic spray bottle or a squirt bottle. It is not going to be in anything long --- the short shelf life.
Mix 1 fl oz at a time, discard any excess when your done or, put in on things you don't want seizing up.
Active
Past
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
I have tried the acetone/aft oil mix. Didn't work well for me. I'm thinking, if it was really that efficient, basically 2-4 times better than the regular brands, I wonder why isn't it actually being marketed? They'd just have to mention to shake well before use.
Here's their testing procedure: to simulate the metal part being 'stuck' by corrosion, they used perfectly clean parts - ie zero rust - then:
"Years of exposure were simulated by twelve hours of alternate immersion using ten minutes in a 3% solution of NaCI (table salt) followed by 50 minutes of drying in 105° Fair."
Is this representative of a 10 years old bolt stuck in rust from salt ?
Plus a penetrating oil must be left for days if not weeks, to be efficient on a very stuck bolt, ie to have the time to leak deeply by the threads and actually work.
I used PB Blaster but it stinks. Now I use Liquid Wrench.
RickHaleParker
Short shelf life.
That is how got a busted head bolt out of a Volvo 2.9, that was broken flush with the bottom of the well. As soon as the Left hand bit started cutting the bolt backed out.
Active
Past
