Can someone please tell me the alignment should be for this car? Looking back through past before and after figs, the after figs vary wildly.
Thanks
Alignment spec V70 Auto SE 10V Auto 1998
- Has thanked: 316 times
- Been thanked: 531 times
Alignment specs can be found here: http://new.volvocars.com/ownersdocs/199 ... .htm#pg136
Front:
Front:
Rear:Toe-in measured on the wheel rims: 2.4 mm +/- 0.7 mm
Toe-in measured on tire sides: 2.9 +/- 0.9 mm
Toe-in measured on the tire sides: 4° +/- 10°
- Has thanked: 2196 times
- Been thanked: 1850 times
That rear alignment spec looks whacky? 4 degrees +/- 10 degrees!! That could give you up to 6 degrees toe-out?
Yeah, that does seem rather strange. That is a lot of toe-out.scot850 wrote: 25 Jan 2018, 10:22 That rear alignment spec looks whacky? 4 degrees +/- 10 degrees!! That could give you up to 6 degrees toe-out?
Must be a typo... my Saab's manual claimed the spark plug gap was .0141" instead of the proper 0.0414" for the base Linear model. Turns out it was just the 2004 manual since the '03 and '05 books were correct. Mine was the Aero, so that specification was correct at least.
- 1179 Views
Last post by misha
- 13 Replies
- 4380 Views
Last post by Ocelot
- 1192 Views
Last post by jeffsws
- 1016 Views
Last post by OffsetBuffalo
- 452 Views
