So passenger side low beam (H11 bulb) is out. I suspect is goes out frequently. By feel only, since I can't see anything in there given tight clearance between brain box and headlight unit, I am betting the bulb retainer clip springs were broken or mangled and there is some sort of jury rig arrangement holding the bulb. What makes me say this is I can get in there and wiggle the bulb and I feel a lot of what seems like masking tape in there. My dear departed neighbor would have referred to it as a kludge job. Vibrating bulbs make for short filament life in my experience.
Couple questions:1) can the bulb retainer clip be bought as a separate replacement part and 2) given the absolute miserable working clearance in there, has anyone contemplated actually removing the passenger side headlight unit just to replace the low beam? I am definitely considering it.
2006 V70 -- Low Beam Blues
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
Get your self a nice inspection mirror so you can see what you are doing
That job is a pain on P2 s
I remember it was the very first thing I had to do on my 2005 and s badly made headlight socket made it s 3 hour job
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
You just need to accept that you'll cut yourself and it will go a lot fasterabscate wrote: 28 Jan 2018, 23:25 Get your self a nice inspection mirror so you can see what you are doing
I've got the xenon low beams. They make the halogens seem roomy in comparison.
- RickHaleParker
- Been thanked: 978 times
A Endoscope can go where an Inspection mirror cannot. Even a cheap USB Endoscope off eBay makes a difference.
Active
Past
Past
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 79 times
- Been thanked: 71 times
OP said, "I am betting the bulb retainer clip springs were broken or mangled...."
There are no clips involved. The H11's lock in with "1/8" turn.
The wise thing to do is see how the old bulb is oriented before you remove it. A mirror can help here. Also, a mirror can help you see the lugs. I key in on the wider lug.
Another challenge is that the fixtures are made of layers of material such that rotating the bulb once in its hole and hoping it will fall into position can't be done easily.
Way before WWII when the French navy ruled supreme, when you were demasted you rigged a day mast - one that only lasted for the day. French 'jour' for the day became Jour rig which we stole of course.
My Latin teacher will also be proud if jury Latin roots in help or alleviate -
Like most word origin fights, There are as many theories as etymologists - but I like my sailing one.
MVS - car repair, humor,and intellect (?) all for the same low price..
Georgeandkira
I've stricken my etymological offering for two reasons.
1) I'm not 100% sure.
2) 'Twas a highly questionable source who told me about "gerry vs. jury" rigging.
The next time Patricia T. O'Conner (The Word Lady) is on the radio, I'll ask. She knows everything!
- E Showell
FCP's website says my car takes the retainer clip.
'95 855 auto (sold)
'95 855 auto (sold)
Ringo
- Year and Model: 2006 70XC
- Has thanked: 33 times
My 2006 xc70 2.5T has the 1/8 COUNTER-clockwise turn. Put the electrical connector on first. I found a YouTube video that showed a guy taking the brain box out (leaving the ECU and TCM in place) but I didn't want to mess with that ( starting at 3:50 )
2006 XC70 2.5T auto (B5254T2) 125K 2nd owner
1999 V70 XC 2.4T auto (B5254T) 250K Trans failed 2018
1967 122S 2-door auto (B18B) 125K (ex-wife got it 1991)
EngineeringBloke
- Year and Model: 2006 2.5T S60
- Has thanked: 57 times
- Been thanked: 39 times
If I have to work on the passenger bulbs on my '06 S60, I pop off the ECU lid, and raise the rectangular ECU sleeve as shown in the video above at 4:00. There is one clip at the base of the sleeve at front and as well as one on each side holding the sleeve down. I just tried it now and it was much easier than shown on the video - removing the sleeve is quite straight forward. Doing this gives you a lot more access to the bulbs.
Note the sleeve is shaped like a boot. As you raise it, and once it is up about 4 inches, you can tilt it towards the front of the car to avoid the projection getting stuck. No need to force it, and take note of where the ECU and TCU mounting module edges fit in the sleeve's grooves for when you replace it. There is an extra groove on the front corner of the sleeve that is not used.
I also remove the windshield washer fluid fill tube to get at the corner behind the lights for the passenger turn signal and position marker bulbs.
Interestingly, the manual does not provide explicit instructions for the passenger low beam bulb replacement - no picture and has the following line:
"Certain bulbs not listed here should only be replaced by an authorized Volvo service technician. "
http://new.volvocars.com/ownersdocs/200 ... .htm#pg150
Accessing the bulbs can be quite aggravating.
- 16 Replies
- 3303 Views
Last post by hu5ker555
- 1636 Views
Last post by EngineeringBloke
- 991 Views
Last post by dennyp2
- 1094 Views
Last post by adrian22
- 3552 Views
Last post by 93SCMax
