IPD sale Volvo Parts
Did you know? 🤔
Cold start . Rpm dips
1996 - 2004 S40
1996 - 2004 V40
Ivano2937
Year and Model: 2004
Has thanked: 2 times
Been thanked: 0
United States of America
Ivano2937
Re: Cold start . Rpm dips
Post by Ivano2937 » Thu Mar 15, 2018 2:16 pm
RickHaleParker wrote:
Thu Mar 15, 2018 9:25 am
Is the engine dirty?
Did you get grease or oil moved around as you changed the IAC?
You sure it not heat burning off oil or grease.
If the engine is dirty, take it to a car wash and wash off the engine, see if the smell goes away.
So it turns out one of the injectors has a rubber that's going loose?
How hard is this to fix myself? It seems like it needs to be readjusted?
RickHaleParker
Been thanked: 251 times
RickHaleParker
Post by RickHaleParker » Thu Mar 15, 2018 4:57 pm
Align and Tap ... Tap! it back down with a rubber mallet. Make sure you don't damage the O-Ring.
Platform: P80 1998 C70, B5234T3, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
QUARKS40
Year and Model: 2010 XC60
Has thanked: 0
QUARKS40
Post by QUARKS40 » Sun Mar 18, 2018 7:40 pm
+1
If you do damage it though, the fix is to remove the fuel rail, which is easily done, but when you do, you will remove all the fuel injectors with it, except possibly the one with the damaged o-ring in your case. You will want to replace all the o-rings at that time, top and bottom, of all the injectors. you'll need p/n 30731083 qty 4
I have some questions though..........
How many miles on this vehicle?
How long do you plan to keep it ?
2010 XC60 - P*, 3 Spoke steering wheel retro, Gearshift retro.
2001 S40 - 14T, BBTB, turbo back stainless DP, Upsolute, KW, 15mm rear sway, 17" Konig wheels, Custom Arctic Silver/Sonic Blue pearl paint, custom interior
