1995 850 noise under hood with and without running engine
rred
Year and Model: 1995 850
Post by rred »
This is a 1995 850 with more than 170k miles. I've been driven it for about 10 years.
What I notice is some noises under the hood.
Without starting the engine, I can hear the following sound.
I feel it comes from someplace at the passenger side. But not sure where exactly it is.
After starting the engine, besides the above noise, I can hear a louder noise with less frequency and I can see the engine is shaking a little bit.
I have no idea about the first noise. About the second noise, I found some posts and it looks like it may be caused by the serpentine belt idler pulley. Any suggestion about the causes of the noises and how to repair them? Thanks a lot!
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
Sounds like your Secondard air pump. Not hard to find, it is a electric motor powered air pump. Unplug it see if the sound goes away.
Active
Past
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
- Without starting and the Aux Fan is running in the first video...probably bad Aux Fan Relay shorting out.
- You have many many issues: bad idler pulleys, maybe bad alternator bearing etc. etc.
- Best is to overhaul the timing belt, pulleys x2, hydraulic tensioner, serp belt, serp belt idler pulley. While there, check the alternator bearing.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Could be a wiper motor for the head lights.
You can pull the serpentine belt and start the car to see if any belt noise continues in the timing belt path.
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
What song was that in the background? Kind of catchy =)
First clip sounds to me like the secondary air pump - I've had them whine and not growl. If it were it would only do so for maybe 30-60 seconds after startup. Since it is also happening without the engine running - I'd look at the cooling stack.
Second clip sounds like a slightly bad bearing on a pulley or idler.
rred
Post by rred »
Thanks a lot for all your advice.
The first noise turns out to be the motor for headlight wiper. Somehow it gets stuck. I'm not sure whether I'm going to fix it or just disconnect it. I don't fell the headlight wipers very useful. Actually, the driver side one has missed the wiper for years.
Has thanked: 1609 times
Been thanked: 4064 times
They work a lot better with the wiper
Has thanked: 2197 times
Been thanked: 1850 times
Just disconnect it at the plug above the rear of the headlight on that side. The motors need to be stripped and re-built once in a while (maybe 10 years?) as they get sticky and don't always return to base when used, or can break a drive tooth preventing returning to base position.
rred
Post by rred »
Thanks, I think I'll just disconnect the flug.
