1996 850R Rims Needed
wackenhut
Year and Model: 850R 1996
Post by wackenhut »
Does anyone know where I can find some used volans?
Unfortunately I cracked 3 of them :(
Also, if I just needed some rims...what can be used as substitutes for now?
I believe my size is 205 45 17
Would s70 rims work?
Thank you.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
Volans are 17x7, so any Volvo 17x7 wheel with 43mm offset and 5x108 pattern should work fine. Check Craigslist and eBay.
Any S70/V70/C70 wheels are a direct fit. Most all Volvo wheels are, actually.
iPd has a wheel cross-reference chart that is quite helpful: https://www.ipdusa.com/techtips/10128/v ... -reference
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
The line for the Volan's starts back there around the corner. lol
bmdubya1198
rspi wrote: 05 Feb 2018, 09:14 The line for the Volan's starts back there around the corner. lol
Hahaha, same goes for Comets!
skloon
Year and Model: 94 850 95 850 04 S60
Been thanked: 2 times
Post by skloon »
Were you trying to find the source of the Nile ?
Has thanked: 1611 times
Been thanked: 4075 times
skloon wrote: 05 Feb 2018, 10:55 Unfortunately I cracked 3 of them :(
its the Crocs down in FL - they chomp on the wheels when you stop at the lights. They are even tougher on the CV Gaiters...gators?
skloon
Post by skloon »
Thank goodness the winter in Alberta kills off the crocs- or at least the people who wear them in public
bmdubya1198
And is his name James May by chance?
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
bmdubya1198 wrote: 05 Feb 2018, 09:13...Any S70/V70/C70 wheels are a direct fit. Most all Volvo wheels are, actually...
S60 & S80... too...they have offset of 49,but as long as you stick with 205 width tyres...they will fit fine.
About offset...factory offset is 43,but everything between 35-49 will fit fine. ;)
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
look at the thread for phase one alloys in the wheel and tire forum, 15s and 16s will also work if you have "normal" brakes. As for the S60 and S80 wheels, check hub diameter too, you may need adapters.
Current Volvos:
