I recently bought a 07 XC90 with 146k. Everything handled nicely until a snow storm hit and noticed AWD isn't working. I checked with a ViDA DiCE and it said (DEM-P188914 Oil pressure pump performance. General electrical fault. Short circuit to ground or open circuit) code. I took it back to the dealer and they installed a new pump and added new fluid. The error code went away and the same day a new code appeared. This time it's saying (DEM-P188974 Oil Pressure Pump Performance. Mechanical Failures. Actuator slipping).
I'm lost at this point. Any help is appreciated.
The below attachments are of the diagnostic report.
2007 XC90 3.2 AWD Issue - DEM-P188974
thebull
- Year and Model: XC90 R-Design 2009
OK now.
First: Check your DEM-P188974-Error Code-Details.pdf report. On the very end you will see Rear Right goes like "Velocity rear right 166058.09 km/h". It is like Apollo 11 going to the Moon. Check you wheel speed sensor there.
Second:
Third: Check that you angle gear is OK. Go under the car and grab your propeller shaft with hands and force it to turn. It should NOT turn. If it is turning - new angle gear. I do not think this is your problem but does not hurt to check.
Fourth: Could be DEM electronic module sending BS and has to be repaired.
I believe your Haldex filter is almost clogged and the clutch is slipping.
Good luck
Second:
Did they replace the small filter there? If not - off you go. Do it asap.I took it back to the dealer and they installed a new pump and added new fluid.
Good luck
Flying on 2009 XC90 R-design 3.2L AWD and 2006 XC90 2.5T AWD. Volvo owner forever.
- ggleavitt
- Year and Model: 06,08 XC90 V8
- Has thanked: 26 times
- Been thanked: 134 times
And?
Waiting on the other site as well, someone else had mentioned pressure sensor maybe? Not enough fluid?
Sorry, for the delayed response.
The issue is now fixed. Below is listed all stuff replaced
DEM-P188914
The dealer replaced the following:
AOC Oil Pump - Dorman 699-002
Haldex Fluid
DEM-P188974
Pressure Sensor - 30759668
Coupler Filter - 30787687
O Ring - 925263
Haldex Fluid
DEM-P188914
Haldex Fluid
DEM-P188974
O Ring - 925263
Haldex Fluid
- 5365 Views
Last post by Powza
- 658 Views
Last post by Brunsa
- 457 Views
Last post by ggleavitt
- 5678 Views
Last post by vtl
- 968 Views
Last post by mrjacobrussell
