I'm replacing the leaking radiator from our 2007 C70. I have found nowhere on the web what the procedure is. At this point I have the front fascia off, headlights out, splash shield under the radiator out, the four hoses (2 radiator, 2 intercooler) and the four bolts holding the radiator cradle are also out. The cradle is being supported by a jackstand.
What I can't find out is what comes out with it. Looks like the intercooler definitely, what about the fan? The oil cooler ext to the fan?
How does the electrical connector for the fan, which is mounted on the fan shroud, disconnect? Very tight and very tight space.
Fwiw, I subscribed to Alldata.com for the 2007 C70 and had to request a refund as their manual is for the P80 platform C70, not the later P1 hardtop convertible. Entirely different animal. Might try Chilton's online next but have asked for confirmation on the platform.
Thanks,
Roman
2007 C70 Radiator Removal?
- RickHaleParker
- Been thanked: 980 times
See the attached file.
2007 C70 Radiator Replacement..pdf- (580.93 KiB) Downloaded 265 times
Active
Past
Past
- 1810 Views
Last post by Samzebian
- 1861 Views
Last post by precopster
- 3637 Views
Last post by t3yf5g
- 7181 Views
Last post by jalwlb
- 228 Views
Last post by volvolugnut
