Hi,
My glove compartment door is not closing because the U-Shaped latch that goes into the door release mechanism is loose. Is there a fix or some sort of backing plate because the two screws holding the U-Shaped latch are not tightening properly.
Every time I go to shut the glove compartment door, the latch moves up or down and not catching.
Thank you.
1996 850 Glove Compartment Latch Issue
- RickHaleParker
- Been thanked: 980 times
If it is plastic, fill the holes with JB plastic weld epoxy. When fully cured, drill and make new threads.
If it is metal, tap threads to next size and use next size bolt.
Active
Past
Past
- Oly850
- Year and Model: In acquisition mode.
- Has thanked: 53 times
- Been thanked: 22 times
It's broken plastic underneath the vinyl for the dash above the u-shaped hook for the latch. My '96 had the same problem. There isn't much you can do but epoxy a stick of plastic behind the broken pieces and hope for the best. I ended up replacing my dash from a junkyard find because my AC evap box was cracked and sucking air. Not for the faint of heart, took all day.
Looking for a V90 to be my next Volvo, at the very least a T5.
2017 XC90 Inscription - My best Volvo by far, but Ex-wife departed & I had to sell.
2001 S80 T6 - rebuilt trans, head gasket, fixed & sold
1997 V70 - kid car, sold
1996 850 GLT - found under bridge, 2 year refurb project, commuter car, kid car, T-Boned - SIPS saved passenger. Totaled.
1997 VW GTI VR6 - exceedingly fast.
1971 VW Type II/231 - it was pointed out by management that the children would be killed in it.
