Hello,
Anybody try Pentius, Amsoil brands of air-filters? How have these brands of filters boosted fuel economy?
Thank-you
Engine air-filters:
- Has thanked: 17 times
- Been thanked: 35 times
Although I do not know the answer, you do not specify which car you have... Please list your model year, model and type ('04 S40 T5, etc.). A turbo car would make more of a difference depending on filter than a non-turbo car.
- June
- Has thanked: 523 times
- Been thanked: 261 times
I looked and for my car 04 S80 the Penius air filter is under $10.00, I think Volvo charges $60.00. Being so cheap it would be interesting if their product turns out to save gas. If you get results please let us know. I achieved a 1 to 3 mpg improved mileage since switching from the dealership Castrol synthetic 5w30 to Redline 5w30. Same Volvo filter, Shell 93 from the same station I always fill, and same normal weekly driving routes. Just a ester based 100% synthetic oil. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
On a stock car it shouldn't be able to make a difference. They're not exactly being used near capacity when new since there has to be room for a few years of dirt in them between changes.
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
Agreed. If you are really driving to get best MPG then the low CFM of air you pass through airfilter will not create any issue that air filters will improve.
EcoVehicle
- Year and Model: 2009 C30
My vehicle is a 2009 Volvo C30 Turbo. How does outside air-flow through the air-intake duct play a role in fuel-economy?MadeInJapan wrote: 17 Feb 2018, 06:47 Although I do not know the answer, you do not specify which car you have... Please list your model year, model and type ('04 S40 T5, etc.). A turbo car would make more of a difference depending on filter than a non-turbo car.
more air more fuel...it won't help fuel economy but could/will make a difference in turbo boost.
- Rattnalle
Only if you modify the software as well. The original software will try to adapt back to its specified performance if you change parts. It won't take any advantage of higher air flow for example.MadeInJapan wrote: 20 Feb 2018, 04:59 more air more fuel...it won't help fuel economy but could/will make a difference in turbo boost.
Good point- I forget that my ECM has been flash upgraded. Btw, I use a Typhoon filter and intake and got rid of the regular air box for this reason on my S40 T5.Rattnalle wrote: 20 Feb 2018, 05:16Only if you modify the software as well. The original software will try to adapt back to its specified performance if you change parts. It won't take any advantage of higher air flow for example.MadeInJapan wrote: 20 Feb 2018, 04:59 more air more fuel...it won't help fuel economy but could/will make a difference in turbo boost.
I will say that cooler air can make a difference in helping your car run better (and less wear)...that's one reason many attempt to get air into the intake that has minimally been heated by the engine bay.
- 1087 Views
Last post by Asmac64
- 1159 Views
- 784 Views
Last post by wanderdüne
- 2437 Views
- 13 Replies
- 6683 Views
Last post by amblerman
