Greetings-
I've searched this forum extensively but did not find the exact info I need.
I need a manual transmission for 1995 Volvo 850 GLT, or so the independent shop says.
I found an extremely low mileage 1996 850 manual transmission (30K, yes...) for $300 but it appears there is some "speed sensor" difference between the model year 93-95 series and the model year 96-97 series. Or so I am finding in the technical descriptions for the used transmissions.
Couple questions:
1) Isn't an M56 manual transmission the same for all 850 series?
2) Is it just the speed sensor or some other issue?
3) Can't I remove the speed sensor from the old transmission and install on the new?
4) Do I have to stay with 93-95 850 model year manual m56 transmissions? (Note: I'm not talking about installing M66 or any other model...this is just plain confusing.)
5) Also, will Volvo OEM R clutch fit into this transmission? I bought one with all Volvo OEM main seal, throwout bearing, pilot bearing, slave and master. (Yes, I am keeping this car.)
6) Why do I keep driving this car?
Volvo gods, please help me or I will start swearing in Swedish since I speak it...(Djaevel anama... fit och fan...osv, osv, osv)
Somebody, throw me a bone or a wrench.
thanks
Mark
YV1LS5504S1226658
Chassis Number: 226658
Model Year: 1995
Model: 850 Sedan
Factory: [Sweden] Torslanda Plant VCT 21(Volvo Torslandaverken) (Gothenburg)
Engine Code: B5254FS MOT 4.4
1996 850 manual transmission bolts into 1995 850? Speed sensor?
- skloon
- Year and Model: 94 850 95 850 04 S60
- Been thanked: 2 times
You can use that transmission and that clutch- to get the speed you just have to tap into an abs sensor there are lots of m56 differences different strengths as well as internal or external slave- I put an 05 into a 94 and had no speedometer issues once I tapped into the drivers side ABS sensor- I still don't have cruise thought
- misha
- Has thanked: 155 times
- Been thanked: 432 times
1995 850 CAN'T have Motronic 4.4.
It's a bit rare even in '96 but ALL '97 have it.
1995 850 n/a B5254FS can only have Jetronic engine management.
About transmission compatibility....skloon already answered it.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
tryingbe
- Year and Model: None
- Has thanked: 1 time
- Been thanked: 26 times
Convert the 1995's speed WIRING to get its signal from the driver side ABS wiring at the wheel. Splice the ground wire to ground and signal wire to signal, use a multimeter to see which wire is which.
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
- 1316 Views
Last post by Nevada1906
- 687 Views
Last post by ThaddeusTheBold
- 526 Views
Last post by misha
- 271 Views
Last post by pablosvolvohaus
- 1289 Views
Last post by ducttapeandzipties
