srs light
spadeo617
Year and Model: 1999 s80
Post by spadeo617 »
I have a 99 s80 and i just installed a pioneer avh201ex radio and my srs airbag light is on. Ive been told that i need another harness to complete the loop so the airbags are active and the light goes, and I've been told that i dont need the harness i just need a mechanic with the right scanner to shut the light off. Somebody give me the best advice. Last thing i need is to get into an accident and not have working airbags.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
The light is actually not related to the airbag function, it's just that the communication network is, among other modules, connected to the airbag system, and the network was disrupted by the aftermarket radio. I'm not sure the light can be cleared as long as the original radio is out. But the airbags, seat belts, should work fine even with the light on as long as the light went off indeed when the radio was replaced.
spadeo617
Post by spadeo617 »
So what would do you think i should do cause that light is pretty annoying to see.
bluesguys80
Year and Model: 2000 S80
Post by bluesguys80 »
Take it to someone who can read the code. It will tell you specifically what it is. Mine was for the driver seatbelt switch. replaced it cleared the code and never came back on. Now if you can FIND that person who wont charge you and arm and a leg to read the code, erase at your on risk. There are VERY few shops, obviously Volvo, that can read SRS, UCM etc codes.
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
If a SRS harness was disconnected when the key was on, that would set the SRS fault light. Make sure you got all the harness reconnected and then have the fault code cleared.
Active
Past
