Plan on replacing front strut mounts in my 2011 S60 this weekend. Have not found much in the way of DIY on the net. Any one have experience with this fix?
Understand the need to pull wheel bearing from CV shaft (undo bolt to allow spline to slide back) and drop control arm. Then lever assembly down to pull strut. Should I expect any issues?
Appreciate you support.
David
2011 S60 AWD
Replace Strut Mounts
- 1416 Views
- 505 Views
Last post by Vovo_merz
- 1676 Views
Last post by MadeInJapan
- 935 Views
Last post by oragex
- 887 Views
Last post by bmdubya1198
