Hi. So, on cold mornings as I turn the wheel I get no power steering assistance for about the first 5 to 10 degrees. As I turn harder to get it to move the power steering suddenly kicks in and since I'm pushing hard the steering (and the car) then jerks over in that direction until I can react and correct. It seems worse at higher speeds.
After about 10 mins of normal driving it starts working fine. I can get it to work sooner by working the wheel back and forth through the dead points while waiting at the lights.
When in for brake change I had the mechanic check the fluid, it looked clean and at correct level.
Is this a pump problem? A sensor problem? What should I try changing first?
2004.5 S40 2.4i
Power Steering Erratic S40 2004.5 2.4i
- 1780 Views
Last post by Shift727
- 815 Views
Last post by reesea17
- 1485 Views
Last post by wizechatmgr
- 1432 Views
Last post by metalriff
- 1011 Views
Last post by saulgar1
