I'm trying to cut down the price of my shopping list, so I'd like to make sure I'm not buying any 'extras'
For instance, I'd like to know a good way to diagnose my CV Joints, so I could find out whether I have to drop $120 to replace them both, or $20 for a boot kit?
Also, I'm going in deep to replace the main seal, subframe mounts etc.. and I'll be right next to the Clutch assembly, which I figure I might as well replace while I'm there (I think I've got 220k on the original assembly?) Do clutch's "Wear out" and need to be replaced, fast enough that it would be advisable to preemptively purchase a $180 clutch assembly kit? I don't have any symptoms of a 'bad clutch' that I know of, how would I tell?
Anything helps, Thank you!
How to Diagnose CV Joint, Clutch system? ['97 850]
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
If you're pulling the transmission, do the RMS, clutch, and throw out bearing. Replace the slave cylinder if it's leaking (I think you have an external slave). Clutches are wear items and you're already puling the trans to replace the rear main seal. Do both and then not worry about either for another 200k miles.
Knows enough to be dangerous
- gmh
- Year and Model: 2016 XC60 T5
- Has thanked: 28 times
- Been thanked: 22 times
There are plenty of threads in this forum about the pitfalls of replacing your original CV joints with aftermarket. If the boots are intact and the joints aren't clicking, replacing the boots is all that is necessary. The OEM manufacturer is GKN Loebro and these can be found from vendors such as http://www.rmeuropean.com/ and https://www.autohausaz.com/ . Otherwise buying the Volvo branded boots is recommended.ToriWhite wrote: 22 Feb 2018, 20:57 I'm trying to cut down the price of my shopping list, so I'd like to make sure I'm not buying any 'extras'
Gary
1969 145S (1987-91)
1973 145E (1989-90)
1981 245 (1990-2001)
1981 244 (1991-2002)
1989 760 Turbo Wagon (1999-2011)
1994 850 Turbo Wagon (2002-2013) burnt valve
2001 V70 2.4T (2009-2017) sold
1997 850 R Wagon (2013-2025) sold to Matthew
2014 XC60 T6 (2017-present)
2016 XC60 T5 (2024-present)
1969 145S (1987-91)
1973 145E (1989-90)
- 11 Replies
- 3159 Views
Last post by theWIFES_S70
- 28 Replies
- 8602 Views
- 35 Replies
- 16977 Views
- 842 Views
Last post by Atis
- 2293 Views
