The other day I was at a gas station and the guy next to me had a dead battery and asked me for jumper cables. I had the cables but when I opened my hood I realized I didn't know where to hook up both cables. I knew my battery is in the trunk, but when I took a look at that it became clear that it's a project to get to that.
We used my cables but a third car to get the guy going. Is there a way to hook up both cables under the hood on a Volvo to start someone else's engine?
How to jump start another car using a V70?
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
I never had luck using the red connector under the hood along with a ground near the engine. The engine would simply not crank. Maybe I didn't use the right ground point.
However it worked every time when attaching the cable at both poles at the battery inside the trunk. Reason why I threw away the battery cover and just keep a piece of cloth over the posts (just as an extra safety feature so as not to ground the red post). Gives access right away to the battery if needed.
- mrbrian200
- Has thanked: 7 times
- Been thanked: 84 times
I've kept the plastic cover for my S60. The plan is to cut away both corners than reattach those pieces with some sort of hinge so that I can get to the battery terminals with jumper cables without going through the trouble of removing the plastic cover. I agree it's so much easier to jump start another car from the battery in the back. I did it once, removed the cover, and never put it back. I used part of a large inner tube draped over the battery to protect the terminal.
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
I've used the hood connectors a few times and it's works like a charm. I connect the ground wire to the ground connectors on the inside of the fender.
Both starting my own car and helping start others.
- oragex
Rattnalle wrote: 24 Feb 2018, 12:39 I've used the hood connectors a few times and it's works like a charm. I connect the ground wire to the ground connectors on the inside of the fender.
Will keep that in mind for the next time, as a grounding point.
JRL
- Year and Model: Several
- Been thanked: 16 times
One of the strut mount nuts is also a good ground
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 80 times
- Been thanked: 71 times
Remember that there's an engine ground strap fairly low on the right side (passenger's side No.America) going to the firewall.
They can corrode away so inspect yours once in a while.
I'm not recommending this braided strap as a jumping ground.
I open the jumper's black clamp and bite two of the bolts on the fender's edge.
- 1500 Views
Last post by WhizzMan
- 34 Replies
- 4104 Views
- 1036 Views
Last post by oragex
- 611 Views
Last post by MsVolvos802000
- 604 Views
Last post by bubisamongus
