Hi you all:
I own a 2001 S60 with 130,000 miles and during a week long trip away from home the driver side ventilation vents began discharging warm air out of the right vent and hot air out the left vents, which I had to close, with an outside temperature of 70oF
When I got home I changed the air switch from one position to another and the problem went away even after I put the switch back to the original position. I then took the car the Volvo dealer and was told that I needed a software update at a cost of $130 or the problem will return.
Has anybody had this problem before? If so, what was the fix?
Thanks for the help
2001 S60 driver side ventilation
marrieta611
- Year and Model:
nepomuceno
I've not come across this before - but if the dealer is saying that a software 'upgrade' is required to fix the problem - then that's pretty much them admitting the original software was pants and they have created a fix.
I'd argue that it was obviously faulty out the factory, and they should be obliged to correct the fault foc.
vipes
vipes
Hi
Something is wrong,because "software upgrade" have lower cost, as I know for exemple to do one upgrade to CCM node cost less than 1 Euro.
Also, I can tell you that you can ask dealer only calibrate all damper motors, using VIDA. That will solve your problem.
- 1270 Views
Last post by crankycar
- 3795 Views
Last post by leavealetter
- 3743 Views
Last post by LostFoam
- 303 Views
Last post by chrism
- 8758 Views
Last post by dcm0123
