Hello, having some issues on my 2004 C70, and hope you can help.
Last night when I parked my car, I noticed tail lights were still on after the car was off and key out of ignition. Got in, started up, and it immediately went into winter mode and wouldn't exit. Turned off and on a few times, shifting through each position. Eventually it went out of winter mode, but now check engine light is on. Ran code reader with Torque but didn't get a faults. I check online to see if there was something else I can do and see mention of pulling up the DTC menu by holding the read button on the turn indicator while ignition set to II, and toggling the fog lights. No dice. See others complaining about that method not working for their C70s either.
Anyone got a clue? I can't afford to take it in to the dealer, plus I don't have one close by.
2004 C70 P80 platform Check DII codes without scanner (DTC menu)? Check engine light on '04 c70, OBDII shows no codes.
- RickHaleParker
- Been thanked: 978 times
Does not give the codes per se.
Volvo hidden menu – procedure
DTC SET – errors found in module
CHECKING – waiting for information from module
READY – no errors
Volvo hidden menu modules list (all models)
- Turn ignition to II position.
Press and hold [READ] button on the left stalk AS you Press [rear fog lights] button twice.
You should see “CHECKING DTCS” message on the DIM.
Release the [READ] button.
After few seconds you should see “DTCS IN VEHICLE” message.
Use READ button to browse through the hidden menu.
READY – no errors
- ABS – Anti-Lock Brake System
ADM – Additive Dosing Module
AEM – Accesory Electronic Module
AFM – AM/FM Tuner Module
ATM – Antenna Module
AUD – Audio Module
AUM – Audio Module
BCM – Brake Control Module
CCM – Climate Control Module
CEM – Central Electronic Module
CPM – Combustion Preheater Module
DDM – Driver Door Module
DEM – Differential Electronic Module
DIM – Driver Information Module
ECM – Engine Control Module
EPS – Electrical Power Steering Module
ETM – Electronic Throttle Module
IAM – Integrated Audio Module
ICM – Information Control Module
KVM – Keyless Vehicle Module
LPG – LPG Module
LSM – Light Swith Module
MMM – Multimedia Module
MPM – Media Player Module
PAM – Parking Assistance Module
PDM – Passenger Door Module
PHM – Phone Module
PSL – Power Seat Left
PSR – Power Seat Right
REM – Rear Electronics Module
RTI – Road Traffic Information Module
SAS – Steering Wheel Angle Sensor
SHM – Seat Heating Module
SRM – Sunroof Module
SRS – Supplemental Restraint System
SUB – Subwoofer Module
SUM – Suspension Module
SWM – Steering Wheel Module
TCM – TransmissionMessage Channel Module
TMC – Traffic Message Channel Module
TRM – Trailer Module
UEM – Upper Electronic Module
WMM – Wiper Motor Module
Active
Past
Past
- RickHaleParker
I don't think that's gonna work on a P80...
Your point being? or Are you being pointless?
Active
Past
Past
THE C70 platform is still P80 in 2004, it is the late bloomer.
You use VIDA or a higher end (about 150 USD) code reader.dionescu wrote: 19 Feb 2020, 13:57 OK, and how can we read the codes? It just tells us there is an error.
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
If you’re asking in regards to the 2001 S80dionescu wrote: 19 Feb 2020, 13:57 OK, and how can we read the codes? It just tells us there is an error.
indicated in your profile signature, you’ll get
much more relevent responses in the S80
section of MVS:
viewforum.php?f=11
This is the forum area for the older P80 platform Volvos.
The 2004 C70 owner that originated this post has a unique
Coupe or Convertible that ran on the P80 platform for a few
years longer than the Sedans and Wagons.
Best of Luck!
It’s for a 2004 C70 , which is P80 platform, per first post.
It’s really good to follow the YEAR MODEL ISSUE format in the title
- 5502 Views
Last post by oragex
- 480 Views
Last post by griffks
- 2244 Views
Last post by vtl
- 1708 Views
Last post by Volvo Tank
- 2876 Views
Last post by hu5ker555
