When driving when I rev engine and decelerate fast the electric cuts out for a sec or two and then come on
This also happens sometimes when I take my foot of gas. Its not a constant issue but happens occasionally.
My son says it is the battery but I don't think so. Battery is not brand new but it does always start.
I replaced alternator about 6 months ago.
Any Thoughts Thanks Madness
electric gremlin v70 98
volvomadness
- Year and Model: v70 2003
- Been thanked: 9 times
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
What is the condition of your upper torque mount, and bottom buckle. It sounds like a problem with grounds maybe, due to the engine rocking when torque is released. maybe a cable, or the ground straps? That would be when continuity is lost.
Current Volvos:
volvomadness
thank you will check
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 13 times
When's the last time the throttle body was thoroughly cleaned?
Ditto for the IAS control motor.
M1 10W-30 HM
M1 10W-30 HM
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
Check the battery tray and make sure the thingy-majig is keeping the battery from sliding left to right. If it is missing, it will cause untold intermittent issues - until finally you have nothing.
- 712 Views
Last post by jonesg
- 13 Replies
- 5441 Views
Last post by oragex
- 43 Replies
- 20642 Views
Last post by ylwgto
- 2052 Views
Last post by alschnertz
- 618 Views
Last post by EamonnMR
