2002 C70 door check sheet metal
Brucebo
Year and Model: 850 '96, S70 '99
Has thanked: 3 times
Been thanked: 5 times
Post by Brucebo »
The sheet metal attaching the door check spring on the driver side door tore away, leaving a hole in the door jamb. Looks like I have to weld a piece of sheet metal onto the door to fix this. Anybody else have any experience fixing this, and what to look out for?
Thanks,
-Bruce
Has thanked: 2199 times
Been thanked: 1852 times
Don't recall reading anything on a C70, but not uncommon an issue on 850's and V/S70's. There have been a few threads on this, but try searching under check strap.
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
Unless you have either a really nice MIG setup or preferably a TIG and are quite experienced, you may want to forgo it and bring it to a local welding shop. Odds are it will be only a $100 repair - possibly cheaper. You don't want to overheat anything in there.
They may opt to use a spot welder.
May the force be with you...
