ignition coils has failed due to spark plug large gap
adrian22
Year and Model: s60 2006
Post by adrian22 »
is it possible one or more of the ignition coils to fail (Check Engine Light code Po302)due to too high voltage to spark plug---could indicate excessive spark plug gap.
The old spark plugs gap was 052----- I think should be around 030-all wires ok
I the faulty coil and all the spark plugs and fixed problem
xc 70 2005 118k miles
adrian22
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
No,
Coils fail b/c of internal short (the insulation of the copper windings fails), especially with heat. Get used coils on ebay for cheap.
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
Yes, excess gap is one of the more common root causes for coil failure.
Excessive gap can cause an ignition coil to overheat. More of the energy from the collapsing electromagnetic field gets converted to heat rather then discharged as electrical energy.
Active
Past
Has thanked: 1609 times
Been thanked: 4063 times
I would guess your plugs failed with Wear and your coil failed on time. Your four other coils are probably arguing with the Grim Reaper, too. At very least carry a good spare ( shameless plug :-) but if it’s a daily driver do the other four next payday,
Ive got some cheap spares in the parts for sale Forum as do others, or Pnp.
Georgeandkira
Year and Model: '07 V70 + '15 XC70
Has thanked: 79 times
Been thanked: 71 times
Post by Georgeandkira »
A shameless plug for a coil.......
Gotta conclude the unadjustable "tri-tode" sparky-poos in non-turbos, when replaced on schedule, eliminate that failure point.
If you ever start liking my humor, see your therapist, quickly.
Man went to a doctor, gave him six months to live, couldnt pay his bill...
jonesg
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
abscate wrote: 07 Mar 2018, 06:27 If you ever start liking my humor, see your therapist, quickly.
Gave him 6 more?
A baby seal walked into a club..
I though that one was
A baby seal walks into a bar
what will you have?
anything but Canadian Club
