Hey all.
I'm going through a '96 850 turbo motor, to possibly rebuild.
Pulled apart the oil pump, just to check it out and the relief valve spring measures out to around 75mm. The service manual show that the free length needs to be closer to 82mm.
Everything else in there looks clean, and the rotor/housing clearance is well within spec.
These springs are replaceable, correct?
850 oil pump relief valve spring questions
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
- RickHaleParker
- Been thanked: 979 times
Volvo part number 9146132. Less the $3.50 depending on source.
Active
Past
Past
- 630 Views
Last post by jeffriehunter
- 5896 Views
Last post by DGM
- 634 Views
Last post by Lasershark
- 591 Views
Last post by Sommerfeldt
- 22 Replies
- 2462 Views
Last post by erikv11
