XC90 2004 D5 2.4 diesel 163 bhp (RHD UK) 198,000 miles
About 3 months ago I started to see a small coolant loss. Maybe due to slight weeping from top up bottle beginning to crack but nothing visible anywhere in/under engine, or inside car floor pans .
That has changed quite suddenly. Today in the morning I topped up the coolant level drove into town, 6 miles, drove home 6 miles but on the way home got the coolant low warning. So thats a loss of about 1 pint in 12 miles, getting serious.
Most of the time no dripping underneath but sometime yes, the from left side of the engine block is wet. I'm at a loss as to where the leak is. The thermostat housing seems to be dry so not dripping down from there. I did wonder if the leak is from the water pump but don't see how that would wet the front of the block. Any hints please?
XC90 Unidentified Coolant Leak
cuhfs
- Year and Model: 850,XC70,XC90,S60,80
- Has thanked: 17 times
- Been thanked: 31 times
Pressure test the system. In the US many auto parts stores will loan the pressure tester to you for free.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
- RickHaleParker
- Been thanked: 980 times
Put some trace dye in the coolant then, with a UV light trace the leak back to the source.
Active
Past
Past
- 2115 Views
Last post by precopster
- 1698 Views
Last post by RickHaleParker
- 1092 Views
Last post by volvoAgX
- 332 Views
Last post by denogoh
- 16 Replies
- 4504 Views
Last post by granite
