Replacing: FR motor mount, All cam seals, TB and pulleys. Water pump. Done a lot of reading and watching videos (shout out to Robert!).
Since I’ll get stuck at some point and start a thread anyway next weekend, I figured why not get that thread going now with some of the questions I already have as I’m prepping:
- Is there a fool proof way to set the new cam seals at the correct depth when replacing them? I’ve done a timing belt but never cam seals so I will have no feel for this aspect of it. I would rather buy the special little seating tools than screw that part of the job up, but if there’s a trick that’s free I’ll take it.
- Would you recommend doing the crank seal and oil pump seals while I’m in there or am I probably good at 144K miles? I don’t think they’re leaking, but there’s been oil everywhere on the front of the engine from the exhaust cam down for two months so I don’t really know for sure.
My hesitation is I don’t want to screw up the timing on the engine of course, cams will be locked, but I’d rather avoid the crank seal all else being equal unless it’s likely to go in the next 70K Miles
My Cam Seal Replacement Thread
- Has thanked: 311 times
- Been thanked: 817 times
Seating the seals: On the rears I tap them in with a 36 mm socket. Not foolproof but very nearly so. On the fronts I screw them in with a cut off piece of PVC pipe and a metal plate, with holes in it for the cam sprocket bolts. Foolproof. The keys to remember are that (1) you want the seals to be flush, and (2) it's almost always ok if they get pushed in too far, but I try hard to avoid that. Both the socket and the PVC pipe are slightly OVERsize, so they stop moving when they get to the head surface. Keeps the seals flush. Remove the serp tensioner when you start working on the timing belt side, it makes maneuvering in there much easier. Only two 12 mm bolts.
Crank seal, oil pump seal: wouldn't touch them, never have. Especially not with only 144k. Strictly a need to replace basis and you will have to look very hard on the forums to find case(s) where it was needed.
- jtp
- Year and Model: 99 v70R
- Has thanked: 11 times
- Been thanked: 10 times
Roger. Thanks Erikerikv11 wrote: 15 Mar 2018, 07:48 Seating the seals: On the rears I tap them in with a 36 mm socket. Not foolproof but very nearly so. On the fronts I screw them in with a cut off piece of PVC pipe and a metal plate, with holes in it for the cam sprocket bolts. Foolproof. The keys to remember are that (1) you want the seals to be flush, and (2) it's almost always ok if they get pushed in too far, but I try hard to avoid that. Both the socket and the PVC pipe are slightly OVERsize, so they stop moving when they get to the head surface. Keeps the seals flush. Remove the serp tensioner when you start working on the timing belt side, it makes maneuvering in there much easier. Only two 12 mm bolts.
I wouldnt have thought to remove the serp tensioner so that will hopefully help a lots. Limited space over there is the worst thing about it for me. I have big hands.
I will probably just get the tool for the front seals based on your description. I can round up a 36 for the rears
99 V70R AWD
Almost 155K Miles
Breaking is how I know it’s working
98 S70NA (sold)
95 850 Turbo Wagon (RIP)
Almost 155K Miles
98 S70NA (sold)
Crap - I still have kahls cam seal tool in my garage - reminds me to send it back this weekend. If I find it Ill send pictures
- 9655 Views
Last post by tyguyc
- 2043 Views
Last post by wizechatmgr
- 22 Replies
- 10411 Views
Last post by ggleavitt
- 1491 Views
Last post by iRenaissanceMan
- 12999 Views
