Was driving along and the engine just quit. Pulled over and can't get it started again. The battery turns the engine over ok and there is fuel pressure at the fuel pressure relief valve...so I'm assuming the fuel pump is ok.
Any thoughts on what it could be or what to check?
The car normally runs quite well even though its a high mileage car (600,000 km)
Mike
1998 S90 stopped running...
- June
- Has thanked: 523 times
- Been thanked: 261 times
Had that happen on a Buick and it ended up being the crankshaft sensor. Are you sure the timing belt is ok? Have you had the codes read if any exist? I loved my 98 S90 the short time I had it. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
- RickHaleParker
- Been thanked: 979 times
I have a '97 S90. If the Camshaft Position Sensor (CMP) is defective the engine may not run. However if you unplug the CMP the engine will start and run in derated mode. Try unpluging the CMP and see if it will start and run.
Active
Past
Past
- 2224 Views
Last post by Sixthandredline
- 1325 Views
Last post by tryingbe
- 736 Views
Last post by wizechatmgr
- 11 Replies
- 3006 Views
Last post by Faust
- 1284 Views
Last post by 93SCMax
