Hi
My 2000 s40 windshield wipers now only work on high speed.
I replaced the stalk controller still same..
this problem gradually got worse over time..it started with the intermittent
then low..
now only high speed works..Also they will not park.
I have heard that wipers speeds may be attached to the engine control module?
Is that possible?
Thanks
2000 s40 windshield wipers speed ..
- alschnertz
- Year and Model: 1995 854T
- Has thanked: 2 times
- Been thanked: 12 times
My first guess would be a relay issue.
The only thing I see in Haynes manual is that the "wiper relay is an integral part of the switch assembly".
You changed the switch. Are you sure the replacement switch is good?
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
NoboDY0101
- Year and Model: 2000
it was a used switch
- 9222 Views
Last post by Martin2017
- 1571 Views
- 1207 Views
Last post by Luckyducky
- 956 Views
Last post by JimBee
- 590 Views
Last post by BEJinFbk
