2001 Volvo V70 2.4T
Passing through a junkyard the other day I saw an S60 with a dim cluster that had chrome rings around the gauges. I think it may have been a 2003 or 2004.
Can I swap mine out for one of those? I just thought it looked better...
Dim swap compatibility
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
In theory, that is a 2004+ and will not work on your 2001.
- oragex
I tried to fit the silver rings on my 2003 but it didn't work, the area around the gauges has a diameter juust slightly larger than the rings for some reason. But one may try to perhaps swap the whole housing of the DIM (with the cluster, gauges, glass and white cover), and just keep the original circuit board. Haven't checked myself if it fits.
Daveliz99
- Year and Model: V70 2001
- Has thanked: 3 times
- Been thanked: 2 times
That's a little more than I wanted to do lol, may try the after market though. I was just looking for a quick and easy dress uporagex wrote: 21 Mar 2018, 07:29 I tried to fit the silver rings on my 2003 but it didn't work, the area around the gauges has a diameter juust slightly larger than the rings for some reason. But one may try to perhaps swap the whole housing of the DIM (with the cluster, gauges, glass and white cover), and just keep the original circuit board. Haven't checked myself if it fits.
Maybe if someone else chimes in and has done it before, but I'm no pioneer of these things.
Hnizdo
- Year and Model: xc90 4.4 06
- Has thanked: 1 time
Dim with silver rings pn: 8673262/263... it works with 50% success rate instead of pn: 8637996/993, I probably didn't research why, but I had more success only with 2001. In 2002-3, maybe not a single one worked for me... (maybe I was lucky in the content and equipment of the model).. pcb don't even try to change too many differences only for DIYers.. (change all alarm clocks together.. they have different shades of transparency) for programming dim with silvert ring is readable on both masks but use DASH YAZAKI 0L85D otherwise you will die, and at CanBus Dim does not communicate
- 927 Views
Last post by doublebug
- 1224 Views
Last post by jaces_dad
- 4118 Views
Last post by Antherzoll
- 424 Views
- 20 Replies
- 4426 Views
Last post by FLXC90
