Torque Specs for front end suspension/steering Topic is solved
broadusc
- Year and Model: 2000 V40
- Has thanked: 2 times
This weekend I'm swapping out the control arms, sway bar end links, and tie rod ends. I'm having a hard time finding the torque specs on the interwebs for those parts. Anyone know where I could find that info for a 2000 Volvo V40?
- alschnertz
- Year and Model: 1995 854T
- Been thanked: 12 times
From Haynes manual:
Control arms: "Balljoint nut 49 ft-lbs; Front pivot bolt 66 ft-lbs; Rear mounting clamp bolts 66 ft-lbs"
Suspension strut: "Piston nut 48 ft-lbs; Strut-to-swivel hub bolts 66 ft-lbs; Upper mounting nuts 33 ft-lbs"
Sway bar: "Anti-roll bar connecting link nuts: 33 ft-lbs"
Tie rod ends: "Balljoint locknut 31 ft-lbs; Balljoint-to-swivel hub nut* 18 ft-lbs; Inner balljoint-to-sterring rack 65 ft-lb".
"* If the split pin holes are not correctly aligned at the specified torque, tighten the nut slightly more to bring the holes into alignment"
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
- alschnertz
Glad to help.
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
- 4460 Views
Last post by ktuuri
- 1898 Views
Last post by ThommyKent
- 5844 Views
Last post by Navservice
- 1738 Views
Last post by kosh_al
- 3560 Views
Last post by gibbi42
