1999 V70 XC bad headlight switch?
Avasquez65
Year and Model: 1999 V70
Has thanked: 1 time
Post by Avasquez65 »
I don’t know if this problem has been going with my car since I mostly drive during the day, but the headlights and the gauge cluster just died on me. But I noticed if I push down on the headlight switch the lights turn on for a second and then turn off again - I tried turning the car on and off again but no luck. The high beams work when I pull the lever, but turn off when I let go.
How does one diagnose this problem and how much does it cost to fix? Or is it easier to fix it yourself?
Has thanked: 1609 times
Been thanked: 4065 times
You can try a switch from a pick and pull yard or a new one for Eeuro, iPd or FCP here.
You are in spinner country , Volvo Guru Robert (rspi) is in ABQ and often has a video on his feed covering FAQ
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
- This is safety issue (you can run into no lights at night!).
- I have a HL switch lying around, in very good condition.
- Best is to remove trim panel near the knees (Torx screws). Reach your hand behind the switch and push it out.
- Check the tiny bulbs to be sure they work at night (during the day, cover the switch with your hand and see if the tiny bulbs illuminate).
- If you want my switch, PM me for Paypal info. It is $15 FREE 2-day shipping.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Just did a video these (no need to undo the securing pin on the wire)
