Wipers start when vanity mirror is opened
- Has thanked: 17 times
- Been thanked: 35 times
That's definitely a strange one. It could be that moisture got into the main fuse tray and is allowing some type of shorting between the mirror and the wiper control fuse. I would pull the fuse tray down from under the carpet (it's under the glove box) and take a look. You should be able to figure out which fuses are to which components on the car and go from there...dry, clean and reinstall the fuses. I hope that this helps.
- mrbrian200
- Has thanked: 7 times
- Been thanked: 84 times
In my sister's XC90 when I was replacing a bulb I noticed the wire harness to the UEM/rear view mirror was misrouted and pinched against the metal frame that the upper console bolts to. It wasn't causing any shorts yet, but easily could have. Even if you don't have rain sensing wipers control wires for the system likely are present in the harness. I would start there.
- 1362 Views
Last post by beigg
- 5487 Views
Last post by Clemens
- 2913 Views
Last post by jonesg
- 13 Replies
- 392 Views
- 1614 Views
Last post by phils94850
