Need rims for my 1999 S70 GLT
ashvolvo
Year and Model: 1999- S 70 GLT
Post by ashvolvo »
My front tires leak a few LB every day, did the soap test and figured that the rim has corroded and the tire is not sitting as they should on the rims. I need to get replacement rims for the front wheels. Does anybody have rims they are getting rid of? Let me know.Thanks..!
1999 S-70 GLT @168K Miles
1987 740 GLE- Donated @215K Miles
Has thanked: 2210 times
Been thanked: 1852 times
It is unusual for rims to corrode to that extent especially in CA I would have thought. What does often happen is over the years there is a build up of sealant on the rim edge which needs to be removed to allow a good seal. Most good tire fitters should be able to clean that off to allow fresh sealant to work properly.
How old are your tires? I just had an old spare removed from a rim and it literally crumbled where the tire bead met the rim.
ashvolvo
Post by ashvolvo »
From 1999 this car was in MA and VA, came to CA only in 2016. Or may be the rim is bent??The tires were replaced in 2017, Michelin on all 4 of them
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
- Too bad you don't live here, otherwise I have a complete set of wheels and tires (60% tread remaining for sales).
- Shipping to CA would be expensive...
viewtopic.php?f=7&t=84658
wizechatmgr
Has thanked: 45 times
Been thanked: 129 times
Post by wizechatmgr »
Try having that tire re-mounted. Odds are whomever put it on didn't clean the surface sufficiently. With exception of a rim with a hole in the side or being bent, tires generally shouldn't leak if mounted correctly.
2023 Lexus RZ450e -66k
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
The problem could also be a bad valve.
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
