I'm currently trying to solve some engine codes, a couple are from a bad turbo control valve (P0236 and P0237). The car is making very little boost right now and I ordered a new TCV and tubing to replace the old lines.
The car also has a bad exhaust (clogged cat, running rich). I have plans to fix the exhaust in a month or so. Would it be bad to replace the TCV while the exhaust is still a mess? If the turbo suddenly starts making a lot more boost would I risk damage to it or my engine with a bad exhaust?
Thank you for the input.
1999 V70 AWD Replacing TCV with bad exhaust
deardeergod
- Year and Model: 1999 V70 AWD
- Has thanked: 1 time
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
The TCV only controls the wastegate on ours. The blow-off (CBV) is run directly from the intake manifold.
With the back pressure from the bad/clogged/melted cat I wouldn't expect good boost. We have low pressure turbos.
- 2901 Views
- 1133 Views
- 1557 Views
Last post by CleanGreen98
- 3110 Views
Last post by vtl
- 32 Replies
- 12408 Views
Last post by bronco
